Re: What Grade Bolt - Final Drive Super A
Posted by El Toro on June 24, 2006 at 06:10:02 from (152.163.100.65):
In Reply to: What Grade Bolt - Final Drive Super A posted by scotty on June 24, 2006 at 04:38:27:
I would use Grade 8 or at least Grade 5. Find a place that sells nothing but bolts, nuts and screws. You will need to determine what size you need and the length. You can use a tap to find the correct size. Those threaded holes should have a tap run through them anyway. We have a company in Baltimore that sells only bolts, nuts and screws. If you need the phone number send me an email or post back. Hal
