Re: problem sttarting my farmall c
Posted by gene bender on June 25, 2006 at 13:11:57 from (66.43.221.61):
In Reply to: problem sttarting my farmall c posted by george2125 on June 25, 2006 at 10:50:45:
Get #1 on compression T.D.C. Then make sure the rotor is lined up with the terminal going to #1. Facing the dist cap #1 is about 2 oclock.
