Re: Lack of power - Farmall 300
Posted by Brownie 45 on June 25, 2006 at 17:22:06 from (207.177.82.242):
In Reply to: Lack of power - Farmall 300 posted by Steve Schrader on June 24, 2006 at 15:17:47:
If it is not fuel related, feel the brake housing as the engine starts to pull down, to see if they are hot. Could be a brake getting tight with running[heat].
