12 volt lights
Posted by Squire J on June 25, 2006 at 21:24:11 from (24.118.71.94):
I converted my '48 C to 12 volts, now I want to get all the lights working. My original (6v) lights were missing or junk so I bought a set of (12v) repro teardrop headlights and a used (6v) rear combo light off ebay. My question is what bulbs to use in the rear light. Is the 1195 the correct 12 volt bell shaped bulb for the rear white light? what is the 12 volt replacement for the small bulb with the red jewel cover?
As for the headlights, the ones I bought are already 12 volt and I think they have 1157 (dual filiment) bulbs (they aren't here right now so I can't check). Did the original headlight use a dual filiment bulb for the dim/bright or was it a single filiment bulb and the dim/bright function was done by the resistance coil in the switch? If it was a dual filiment bulb, is there a bell shaped 12 volt bulb?
sorry this got a bit long - really appreciate all the help I get from this site
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
