Re: water pump leak farmall H
Posted by Dave_Id on June 26, 2006 at 15:47:10 from (70.112.233.145):
In Reply to: water pump leak farmall H posted by Eddie123 on June 26, 2006 at 14:18:43:
You didn't need to pull the radiator to get to the pump. Remove the fan blade, and if you have room, try to add one or two packing washers. That might be all it needs, but you may have to remove all the old ones, and put new ones in.
