Re: wet sleeves on super a
Posted by gene bender on June 27, 2006 at 16:23:58 from (66.43.221.61):
In Reply to: wet sleeves on super a posted by amo on June 27, 2006 at 09:29:43:
Just need a lube around the o-rings anything handy will work. Before putting the o-ring in the groove make sure the sleeve goes in easy. You will need to use a short cap screw and washer to hold the sleeve as when you start installing the pistons and rings and have to turn the engine over to tighten the rods the drag on the sleeve will pull it loose. Just dip the piston and new rings in new oil before installing in the new sleeve. NAPA has a good lube for the bearings when installing them. good luck
