Re: Initial Carb Settings - Super C
Posted by CNKS on June 28, 2006 at 17:54:36 from (204.249.178.138):
In Reply to: Initial Carb Settings - Super C posted by SuperCDon on June 28, 2006 at 08:30:04:
The A,B,C,SA,SC had more than one brand of carb. Usually the settings are 1-2 turns for the idle and 1-1.5 turns for the main. Zenith is 1 for idle and 1.5 for main - this is for a C, I assume Super C is the same. If it has a Carter carb the specs are probably about the same, but I don't have one of those. BUT, there is no main jet adjustment screw unless you have a Kerosene/distillate carb, a little unusual for a Super C, but I think IH used them until the late 50's, likely mostly for export -- but you could have one. In warm weather your tractor should start without a choke, then open it slightly to keep it running. Carbs used on IH tractors are notorious for flooding, and if they don't start right away they will flood, then as you have found they are nearly impossible to start. I don't have any other suggestions except that the float needle may not be seated properly, and your float may not be adjusted right. For the Zenith, the correct setting is 1 5/32 from the bowl/throttle body gasket to the bottom (top) of the float, measured with the throttle body UPSIDE DOWN. The float should be horizontal with this measurement. Having said all this, I think your problem is a badly leaking carb, requiring disassembly, and inspection. I have never heard anything good about Denny's. Your timing sounds ok. But, when you reinstall it with the marks lined up, it is a good idea to rotate it counter clocwise viewed from the rear, the rotate it clockwise until you get a spark from the coil wire. The manual says you can check this by installing the distributer and pull out the ignition switch, if the ammeter shows discharge, it is more or less (my words) in time and you do not need to rotate it counterclockwise, (points are closed) -- if not rotate it about 30 degrees, then rotate in the opposite direction until it sparks. Dunno why no one else has answered.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
