Re: wd6 magneto ground
Posted by KEB on June 28, 2006 at 19:57:10 from (207.94.27.5):
In Reply to: wd6 magneto ground posted by bob zalinski on June 28, 2006 at 08:45:53:
Agree with Mark Lake. Only way having the magneto energized could make it run better on diesel would be if the compression release valves are leaking. Otherwise, the auxillary combustion chamber would be completely isolated from the diesel combustion chamber, and leaving the magneto energized wouldn't do anything except erode away the spark plugs. Might try a compression check, if there isn't much difference in compression between the gas & diesel positions it would indicate that the compression release valves aren't closing completely. Keith newpuller, just for future info, the WD-6 is a gasoline start diesel, which is a rather unique configuration. It has a third valve in each combustion chamber which opens to an auxillary combustion chamber to lower compression and provide access to spark plugs for starting like a conventional gasoline engine. Once the engine has warmed up a little, its switched to diesel by closing the auxillary valves and applying throttle to the diesel injection pump. The magneto is only used while its running on gas; once on diesel it uses compression ignition just like any other diesel. ;)
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
