Re: Grinding noise in H axle
Posted by Janicholson on June 29, 2006 at 04:18:01 from (134.84.102.136):
In Reply to: Grinding noise in H axle posted by Illinois Farmall on June 28, 2006 at 20:39:24:
Several potential causes exist.
If the unit has noise that is cycling at wheel rates (once per turn) it may be a wheel bearing. Which is wheel removal and, depending on some factors, removing axle housing from main casting, Bull gear removal, and effort.
If the nois repeats at many times the wheel rate, it is probably in the brakes. and is still serious, but easier to fix. Broken springs, or pieces of metal, or debris. Lets hope it is brakes. JimN
