Re: clunk in gear case
Posted by newpuller on June 29, 2006 at 11:17:17 from (138.163.0.38):
In Reply to: clunk in gear case posted by Henry E on June 29, 2006 at 10:18:11:
You Do not have to split the tractor unless you have the 12" clutch. If you have s/n FBK294707 or earlier, you don't have to split the tractor. Take off your gas tank, rear gas tank mount, the rear section of the steering rod and the support for the steering wheel. Then take the top plate off of the tranny. You can inspect the entire tranny and differential by jacking both tires off of the ground and rotating them in nuetral. If you disconnect the clutch shaft you can even inspect the counter shaft. This will tell you all you need to know about what is wrong with the tranny. Like I said if you have s/n FBK294707 you can take the clutch out from under the housing where the belly pump goes if you have to change any gears. One thing about the clutch removal, you have to take the entire clutch out, shaft, friction plate, pressure plate, the works. Even if you have a s/n higher than the one above, which more than likely you do, I would still take the top plate off first so you can split the tractor after your parts are on order.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
