Re: Found grinding noise in H axle
Posted by Farm Girl on June 29, 2006 at 21:39:04 from (166.172.234.185):
In Reply to: Found grinding noise in H axle posted by Illinois Farmall on June 29, 2006 at 19:14:24:
I had the same problem only with the front wheel rim. It happened right after we painted the rims, insert and had replaced with new rubber. It felt like the rear end was hitting on the teeth in the gears. But after riding and watching the rotation of the tire the same noise was in the same place on the tire when it was down on the road surface. Found bolts had worked its self loose. Boy was I happy it was not the rear end. Then it worked its way loose again this week. They do not seem to stay tight.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
