Re: valve clearance adjust.ment
Posted by El Toro on July 01, 2006 at 04:12:14 from (152.163.100.65):
In Reply to: valve clearance adjust.ment posted by george2125 on June 30, 2006 at 15:26:34:
After the engine is heated up you pull the valve cover and adjust them with the engine at an idle.
Set them at .014" with a feeler gauge. Hal
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
