Re: Light switch for 300 (also, again)
Posted by CNKS on July 01, 2006 at 13:04:34 from (204.249.178.138):
In Reply to: Light switch for 300 (also, again) posted by Levi K on July 01, 2006 at 11:13:37:
There is no sarcasm intended here, but in the time you have asked this same question, you could have ordered and received an operator's manual. I will give you what is is my 460 operator's manual, I doubt if it is much different, remember this is for a 12V generator, I do not know if your alternator makes a difference or not. Top middle, rear light; left resistor terminal, Instrument panel light; right resistor terminal, junction block, which splits off the the headlights; lower right terminal, switch to break away connector socket (in the rear somewhere around the tail light); lower left terminal, "lighting switch to rear light (taped back at one end)". Your picture is upside down to the one in my book, this is as close as I can get. Manuals are a BIG help -- you need one. I do not garantee my interpretation!!
