Re: 300 Transmission Noise
Posted by Dave Slater on July 01, 2006 at 14:55:28 from (152.163.100.65):
In Reply to: Re: 300 Transmission Noise posted by Dave Slater on July 01, 2006 at 14:44:14:
Also if lower shaft was removed did you put the correct side of constant mesh gear to front and put spacer, bearing ETC. in proper order. If engine is running rough some tractors will rattle some in neutral.
