Re: 1466 tractor running hot
Posted by noncompos on July 01, 2006 at 17:36:24 from (70.59.141.59):
In Reply to: 1466 tractor running hot posted by Larry B. - 1466 on July 01, 2006 at 05:53:20:
JJK's right on about the cap; that should be a pressure system, and if it isn't building and keeping pressure it'll run hot. Try Allen's temp check first; if guage reading right examine cap carefully, 'cuz they can rust out enough to let pressure out and look perfect. Drop it a foot or so on concrete, upside down (the cap, not the concrete) to see if any rust flakes fall out. Also, look inside radiator when not running with strong light to see if tubes have coating of scale (excellent heat keeper) AND at night shine light thru fins to make sure not dirty/clogged enough to keep much air from being pulled thru by fan (you can suck in a lot of wasps and grasshoppers). Good luck.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
