Re: H ignition problems
Posted by Randy as in Randy-IA on July 02, 2006 at 18:49:00 from (209.152.95.51):
In Reply to: Re: H ignition problems posted by DCW on July 01, 2006 at 19:33:03:
Why is it sweating ? The same reason that a cold beverage does just in reverse . If it's not kept in a climate controlled environment then it cools down at night . But it heats up quickly during the day OUTSIDE the tractor , the INSIDE of the tractor has a lot of mass in the form of iron and steel ( and in the case of the tranny , a lot of fluid ) so it doesn't heat as quickly so condensation forms inside it . That includes the ignition cap . Like a cold beverage just outside in . Not much you can do about it except to work it EVERY day till ALL fluids are hot to the touch and then work it for a couple hours more to evaporate the moisture that formed inside during the morning hours and try the ventillation tricks mentioned elsewhere or you can mount external heaters like magnetic block heaters or set a space heater under it and run them all summer but you'd have to disable the built in thermostat that most of them have . This would be prohibitively expensive in most areas . Another option is a dehumidifier in the storage space but that would only work if it's a garage or some other relitively confined space . Good luck ...Randy
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
