Re: 330u Electrical Problem
Posted by John T on July 03, 2006 at 10:47:34 from (66.244.90.5):
In Reply to: 330u Electrical Problem posted by Tweeter on July 03, 2006 at 09:21:47:
Tweeter, if theres a battery current discharge path heres one way to find it. If you remove the hot ungrounded batery cable from its post and place the wire and alligator clamp end of a test light to it (leave battery cable unattached) and touch the probe tip end of the test lamp to a frame ground it lights up i.e. it finds a current return path (like a SHORT) correct????? Sooooooooo how I do it is take the probe end and touch n prod n probe it to different terminal and wiring locations TO SEE WHERE IT LIGHTS UP I.E. THE SHORT. NOTE The tests n probes need to be made on the upstream BAT input terminals on like switches cuz if its probed to the downstream side of switches where the loads are it would naturally light up since it finds a ground through the loads. WHAT YOURE LOOKING FOR is short return paths that SHOULD NOT be present. The input BAT terminals on switches should not offer a current return path when OFF unless the switch is bad or a wire is shorted etc. Other methods are to remove wires one at a time and see if n when the shorting path stops or if a wire is removed and momentarily scratched/contacted up againt a terminal that has a current return shorting path, a small spark will happen i.e. if theres no current flow available there wouldnt be any sparks when you attach a hot wire to it. DO NOT be making sparks at the batery especially its top. Common places to find a short are frayed worn wires or switches or mis wired gennys or VR's or alternators etc. Best wishes n God Bless John T
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
