Re: fast hitch question
Posted by Allan In NE on July 06, 2006 at 10:08:02 from (148.78.243.26):
In Reply to: fast hitch question posted by Jefd on July 06, 2006 at 09:54:42:
To convert to a 3-point? Yes, bolt on the factory bracket, which should have came along with the center link and the lower link adaptors.
Be aware tho, they don't work so very good and you're not gonna like it. :>(
Allan
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
