Re: H won't shift into 5th!
Posted by williamf on July 06, 2006 at 14:47:15 from (66.82.9.41):
In Reply to: H won't shift into 5th! posted by H fanatic on July 06, 2006 at 14:04:14:
It's possible that there is a problem with the shifter - bent fork not pushing the gear all the way, detent not seating to hold it in place - but it souonds more like a worn out gear. The way that particular gear works - it's not like two rotating opposite each other, it's more like coupling two shafts together - worn teeth will serve to push the two ends apart.
You're going to need to take the cover off. Not a giant job, even I managed it. At least you don't have to split the tractor.
Step one is get a service manual. You can order what you need from here at YTMAG. I recommend the H Service Manual and the I&T. And an Owners Manual for when you get finished. I would stay away from the Tran and Final Drive manual - if it's the one I got it covers several other models that are too unlike the H to be much use.
$25 to $30 apiece seems like a lot compared to the free advice you'll get here, but the pictures are worth it.
Good Luck,Wm
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
