Re: H won't shift into 5th!
Posted by Haas on July 06, 2006 at 18:19:24 from (12.65.60.145):
In Reply to: H won't shift into 5th! posted by H fanatic on July 06, 2006 at 14:04:14:
More than likely, your 4/5 slider gear is worn out. You're going to need to find a good used one from the salvage yard, or a new one. This is a common problem because of starting in 4th and shifting to fifth on the go and grinding the gears. The gear that wears out is an internal and is actually like a splne. Also, your bearings may be worn and have play, contributing to the problem. To fix it, input shaft and gear (with two bearings) at front of transmission must come out through the bottom of the clutch housing and the top must come off the transmission. If you decide to tackle this job, get a parts catalog so you can see from the diagrams what you are getting into and also a service manual is a good idea. Gaskets, bearings, the gear and seals to fix this right will end up costing several hundred dollars.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
