Re: M won't wind up- strange troubles
Posted by the Unforgiven on July 07, 2006 at 06:32:53 from (199.184.119.22):
In Reply to: Re: M won't wind up- strange troubles posted by Delbert on July 07, 2006 at 06:21:12:
The governor is completly unhooked from the carb so you can run the throttle plate shaft with your finger, it is not a case of the throttle plate position not changing, the engine will not respond when the throttle plate position is changed.
