Re: 986 advice
Posted by K.B.-826 on July 07, 2006 at 16:42:01 from (24.180.143.24):
In Reply to: 986 advice posted by DJL on July 06, 2006 at 22:29:57:
Get yourself a mechanical guage. I use a regular 100 psi hydraulic guage, a piece of 1/4" hyd hose with female 1/4" NPT fittings on each end, and an adapter to go from 1/8" NPT to 1/4" NPT. Remove the oil pressure sender from the block, install the adapter, and connect the hose/guage to the adapter. You can buy oil pressure test guage kits at your local auto parts store that come with a guage, a length of hose, and a variety of fittings. Check your oil pressure at full throttle with the engine fully warmed up. I don"t have the specs here in front of me, but I would think you should have at least 50 psi. If so, look for a bad oil pressure sender, bad guage, or bad wiring/dirty connections. We have a 786 at home, that guage never reads above the halfway mark. It"s got almost 9000 hours on the engine and still runs like new, so I don"t worry! Like the other guys said, a full adjustment of your clutch pedal/transmission brake/TA linkage will get that tractor shifting like new. You"ll need a manual to do the adjustments, and you must follow the directions to the letter. Before you adjust, you may want to drop the bottom cover from the speed transmission and check/replace the transmission brake pad, it"s easy to do, and Hy-Capacity makes a ceramic pad that lasts longer. The clatter you hear at start-up is normal. The injection pump has an excess fuel device, controlled by engine oil pressure. Whenever there is no oil pressure, the pump goes to full fuel, which helps in cold starting. The engine clatters because it can"t totally burn all of that fuel. If you think your tractor is bad, try starting a worn-out 30 or 40 series Deere with an inline Bosch pump, they wind up to 2000 RPM and blow the thickest, blackest smoke you"ve ever seen until oil pressure builds. As for your A/C, plan on spending about $1500 to have it fully converted to 134A. That"s the only way to go. If you repair the A/C, you"ll pretty much have to put in a cab kit. Using the TA for engine braking was definetly a huge mistake. That"s the best way to fry the TA brake pack.
Home
| Forums
Today's Featured Article -
Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
