Re: Put in carb kit or not?
Posted by old on July 07, 2006 at 18:01:27 from (4.245.5.80):
In Reply to: Put in carb kit or not? posted by Jimer on July 07, 2006 at 17:42:15:
The idle one isn't the one that is causeing you problems but the main jet adjust might be. What happens if you screw the one at the bottom of the carb in, thats the main jet adjustment. Should be set some place around 1 to 3 turns out depending on your tractor.
