Re: Farmall B cooling system - Pressurized or not
Posted by Roger46 on July 07, 2006 at 19:28:49 from (69.58.143.17):
In Reply to: Re: Farmall B cooling system - Pressurized or not posted by Hugh MacKay on July 07, 2006 at 19:06:08:
I recently bought a new radiator for my Farmall B from the local tractor salvage yard and when I got it home I saw that it had a pressurized radiator cap. I have had it on the tractor for several years with no problems. I can't see what a difference it would make if the system is pressurized (I think it is better). I can't see what effect it would have on the block as they were so overdesigned anyway. I like the pressurized radiator as the non pressurized one I have on my Farmall A will leak antifreeze out the overflow when I go down a steep hill.
Also, you can tell if the radiator is for a pressurized system by where the overflow pipe is located. If it is in the upper side of the filler neck it is pressurized, but if it is down in the radiator it is a non-pressurized radiator. Roger
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
