Re: Farmall B cooling system - Pressurized or not
Posted by Hugh MacKay on July 08, 2006 at 03:44:05 from (216.208.58.124):
In Reply to: Re: Farmall B cooling system - Pressurized or not posted by Roger46 on July 07, 2006 at 19:28:49:
Roger: I do know the difference in those rads. I can also tell you the main reason for the block change at serial number 310300. The block, part number 354898 is a C-123 block and was used at that time in Super C with a water pump. Those blocks that were used in Super A and had thicker sleeves giving the same 113 cubic inch engine, and without a water pump.
Since the larger C-123 piston and sleeve kits will fit in the old C-113 block used in early SA, also A, B and C. Therefor the changes made in the block must have been for cooling purposes. When I say this I'm thinking more of water pump being reason than presurized versus non-presurized. That is not to say what you've done will not work fine.
Back to the block, and why IH did the thicker sleeves on Super A tractors. It was less expensive to manufacture sleeves than cast two separate blocks.
The main reason I said it was unlikely anyone would put a presurized rad on a B is there were only roughly 25,000 of those presurized rads made. You were quite lucky to find one, not a lot of Supers have been junked yet.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
