1466 Hydraulic Problems
Posted by Brian T from OH on July 08, 2006 at 21:02:51 from (12.75.72.33):
I discovered that the hydraulics work when you first start the tractor and the fluid is not at operating temperature. after the tractor has run for a while it will raise the disk and then not lower it. Tried a IH 706 and disk will raise and lower without a problem but if raised (because of 1466 problem) 706 will not lower disk. Help!!!!!
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
