Re: 400 gas to diesel conversion
Posted by Dave Slater on July 09, 2006 at 05:10:20 from (205.188.116.133):
In Reply to: Re: 400 gas to diesel conversion posted by badpenny on July 08, 2006 at 20:07:23:
I agree if engine and head are good on power unit thats a good buy. Without seeing how the power unit is set up can't say for sure what needs changed, but if you have a 450 farmall diesel engine from head down all parts on front and rear of engine if needed to mount in farmall chassis should be there.The distributor or mag from power unit should work with hydraulic pump.
Intake manifolds have a switch on front to kill power to coil if dist.is used, or to ground a mag.
Just use correct setup for each one.
