Re: Need Electricl Schematic-6volt to 12 volt 140
Posted by Gary In Mozarks on July 10, 2006 at 11:04:16 from (64.240.21.167):
In Reply to: Need Electricl Schematic-6volt to 12 volt 140 trac posted by James Lee on July 10, 2006 at 08:12:57:
The picture above is a Delco 12SI
Make sure you have a three wire alternater if you use the picture above. They also make an internally excited one wire alternater that is in common use.(internally excited) they look exaclty the same. (you can convert a one wire to a three wire and visa versa by installing the appropriate voltage regulator in it).
