Re: 706 282D 1234 shift lever no effect
Posted by the tractor vet on July 10, 2006 at 14:58:52 from (64.179.117.121):
In Reply to: Re: 706 282D 1234 shift lever no effect posted by tim schlodder on July 10, 2006 at 14:18:16:
The Cowel is the sheet metal that covers the top of the dash support and rear of the fuel tank . Now on your problem this is going to be fun to fix and i am going to have to give this some though as i have never had one drop down as i have always caught them before this happend .Think -think- thinking more thinking and some more thinking -------------- Just how good are ya with a welder ??????? , If ya are REAL GOOD ya could tack a long bolt on the top of the shifter shaft and place the coupler over the shaft and line up the hole for the groved pin and install a new pin . Then snap off the bolt and install the shaft and replace the pin there . I know i did not do a vary good job explaining this . Pull the coupler off the shaft and go on top and remove the linkage and pull the shaft up . Take a long bolt thatis longer then the coupler and lightly tack it to the top of the shifter shaft that goes into the speed trans cover if it is still up high enough that ya can get ahold of it , then pull it up and hold it till ya can get the coupler over it and align the holes . But make sure that ya get it wright as the tapper is hard to see . And then after ya get the bottom pin in all will be well in WHOVILLE . Now if the pin holes are woren real bad i have had to drill then out and use a bolt with a onsize drill and install a bolt inplace of the pins , but here you will have to grind the head of the bolt way down for clearance reasons and use a half nut for same reason with no threads sticking out of the nut . I wish that i had me one of them fancy high tech camera so i could post pictures it would realy help some of you guys out .
