Re: Spark Plug question
Posted by John T on July 12, 2006 at 07:17:52 from (66.244.90.5):
In Reply to: Spark Plug question posted by Harley on July 12, 2006 at 06:22:52:
Harley, sounds like a lil hotter plug may help your situation. Ive seen guys even add an extra plug washer on some plugs which makes em run hotter. Theres Autolites that fit n work that are hotter then the 3116, but its advantage is its a NON resistor so you might give it a try. Good wire core wires and good adjusted points may help plus dont run the carb any richer then necessary to avoid excess black smoke from over rich running which blackens n fouls the plugs. Make sure the air cleaner n inlet piping are clean n free and the choke opens full n stays open and the floats not set too high.
Dont hesitate to give her a good general igntion tune up (cap rotor wires points n condensor) cuz it can help and its not all that expensive, then start out with the hotter plug n with the carb adjusted if needed n see what happens
Let us know
Best wishes n God Bless
John T
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
