Brakes Farmall 130
Posted by Joe/Mass on July 12, 2006 at 11:46:55 from (66.31.73.111):
Will fluid run out when seperating the rear end to get access to the brake bands. Any tricks of the trade?
Thanks in advance..Joe/Mass
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
