Re: Brakes Farmall 130
Posted by Hugh MacKay on July 12, 2006 at 12:36:03 from (209.226.106.170):
In Reply to: Brakes Farmall 130 posted by Joe/Mass on July 12, 2006 at 11:46:55:
Joe: No oil will run out when you remove the final drives. You may have a bit of leaking if your transmission-rear end axle seals are bad. If that is case your probably already getting oil dripping out around top of final drive, on the inside as opposed to wheel side. Be extra careful removing the left final drive, tractor is rather unstable with that side jacked and final drive is off. Even the right side requires care. I like to drive tractor so opposire wheel has a buildng post beside it and chain top of that wheel to the post. This will stop tractor from going sideways on jack. Another trick I do is put wood wedges in front axle pivot. These items just allow you to work with a bit of confidence tractor will stay put.
Home
| Forums
Today's Featured Article -
Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
