Re: Magman
Posted by randy hall on July 13, 2006 at 20:34:27 from (209.11.236.19):
In Reply to: Re: Magman posted by magman on July 13, 2006 at 17:42:39:
if you would have left the pipe plug in that your machine shop installed you would not have any filtered oil. that pipe is the outlet of the oil filter. it just returns the oil away from the crankshaft and connecting rod so it doesn't splash around.the purolater system uses the small hole in the long bolt that holds the filter canister on to meter the oil.
