Re: Installing HYD. on an A
Posted by Hugh MacKay on July 13, 2006 at 22:04:17 from (216.208.58.122):
In Reply to: Installing HYD. on an A posted by CR on July 13, 2006 at 13:30:24:
CR: Your not out of the woods yet, the touch control unit will not bolt up to the A torque tube. If you take notice the top of the torque tube is flat on the C. The C torque tube will bolt up in the A.
If your going to that trouble you may as well take the engine to and install your crank, pistons and sleeves.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
