Re: Farmall H Problems
Posted by magman on July 14, 2006 at 09:11:29 from (67.142.130.41):
In Reply to: Farmall H Problems posted by Jeff Wenner on July 14, 2006 at 08:45:35:
I AGREE ON THE FLOAT OR SOME JUNK IN THE NEEDLE AND SEAT. Sorry for the caps. Clean it out with some spray carb cleaner through the inlet and let it drain through the bottom then clean the bulbe and line and check the tank for debree.
JON
