Re: 706 pto problem!
Posted by JJK on July 15, 2006 at 08:49:42 from (216.189.131.247):
In Reply to: 706 pto problem! posted by Daveminn on July 15, 2006 at 05:36:46:
Since your asking what you need to fix the pto chances are that you don't have the tool to compress the spring and clutch drum to disassemble the pto. I would recomend that you just remove the pto and bring it to a dealer or somebody that can rebuild it for you. Park the tractor facing down a ditch so all the oil will go forward unless you want to drain it, remove all the long bolts with the exception of the bottom left corner short bolt and leave the other 2 short bolts in. As you pull the unit out the shaft inside may come with and if it does make sure that it gets put back onto the splined shaft towards the front of the diff housing. Also be a little carefull not to bang up the suction tube to much. If all you need is a clutch pack that you could do yourself but if the pto brakes are bad then the whole pto need to come apart. The only adjustment to worry about on this pto is the hyd pressure adjustment for the clutch pack. I like to set this pressure to about 250 to 300 psi and there again you need the special test fitting and guage to check it. Hope this helps if your going to do as much as you can yourself.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
