Re: Installing HYD. on an A
Posted by Haas on July 15, 2006 at 18:08:10 from (12.65.6.195):
In Reply to: Re: Installing HYD. on an A posted by CR on July 14, 2006 at 18:47:57:
Yes, it is on the same side. It was mounted above the generator. This setup was on a Hebard Shop Mule, but I have since moved it to an I-6. I had to make new brackets for the I-6. I still have the ones for the Shop Mule, which I believe would fit an A, but might not fit another pump. I do have a photo. If you send me an E mail, I will send it to you. Can't see a lot because there is a brace for a snow plow bracket that partially obscures the set up in the photo.
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
