Re: Farmall H oil level
Posted by Will Sick on July 15, 2006 at 21:52:56 from (207.177.34.162):
In Reply to: Farmall H oil level posted by Lincoln on July 15, 2006 at 20:07:11:
The oil is check by the two petcocks on the side of the pan . The level shoud be between the two. THe differential has a check plug on the left side beneath the clutch rod. The hydraulic system should have a dipstick under the cap beneath the gas tank. If it does not it holds a total of 6 quarts. It might not hurt to change the hydraulic oil. There is a drain plug on the bottom. I also like to loosen the rear end plug beneath the pto and let out any condensed moisture.
