Re: International 404 Carb
Posted by Geoff NY on July 16, 2006 at 14:42:31 from (24.190.232.22):
In Reply to: International 404 Carb posted by 806 Southern In on July 16, 2006 at 12:59:04:
Did you remove and clean the screen at the inlet of the carb? Let it soak in carb cleaner at least 12 hours. make sure that the float is properly set. Sounds like the screen at the inlet or in the bowl are picking up smutz. Blow out all the lines and the jets with air. good luck. And have fun.
