Re: IH 2000 loader on a farmall 460, will it fit?
Posted by Weldon K on July 17, 2006 at 07:30:57 from (71.28.78.138):
In Reply to: Re: IH 2000 loader on a farmall 460, will it fit? posted by Isaac Mempa on July 16, 2006 at 16:53:16:
If you have capability to fabricate necessary brackets it would not be difficult. You would need a pattern and measurements to go by. Modifying the subframe to fit the rear axle may require lengthening it by adding necessary length of 4x4 tubing. The butt plate which rests against the axle housing might need to be reworked (change shape of it, drill new holes ). The front mounting brackets could be fairly simply constructed with steel plate and angle . If you want, I can send you pages from Operator's manual showing drawings of mounts for various tractors. I have a 2000 loader on a F-856 and a 2001 on a I-504 and can make photos of brackets . The 856 front brackets are built of two separate parts, bolted together, to make a right side assembly and then another assembly for the left side. Brackets needed for a 460 are very similar to these. Rear mounting on the 504 is the same as needed on 460.With pages from manual ,photos and measurements that I can give you ,you could make them yourself or have them built . Reply here if interested. Weldon
