Re: FARMALL A Troubleshooting
Posted by Brownie 45 on July 17, 2006 at 11:00:06 from (207.177.82.108):
In Reply to: FARMALL A Troubleshooting posted by Bill in VT on July 16, 2006 at 04:52:07:
Points & condenser are located in the rear of the magneto. To get to them, remove the distributor cap. Then remove three screws around the perimeter of the plate which holds the distributor cap on. Don't take off the two screws toward the center of the plate, which hold the cover for the rotor drive gears. With the 3 screws removed, pull the plate off , exposing the points & condenser. Everything should be self explanatory from here.
