Re: Farmall M carboning plugs........
Posted by ihwill on July 18, 2006 at 07:27:58 from (207.30.196.214):
In Reply to: Farmall M carboning plugs........ posted by dej(JED) on July 18, 2006 at 07:11:51:
Get hot coil or eletronic ign.& hot plugs such as champion D21 . If you want it to really run good use airplane 100 low lead gas.hope this helps.Will
