Re: Rear Rims On A H Farmall
Posted by Magman on July 18, 2006 at 08:03:29 from (67.142.130.32):
In Reply to: Rear Rims On A H Farmall posted by kfox on July 18, 2006 at 05:29:40:
they should be fine just tighten the lugs a half to 1 turn at a time all the way around so its even and no tight high spots. If the rims are the new ones that fit JDs also you may need to go to a longer bolt in the hub to get them centerd right. alot of the new rims are 1" wider in the center so they will fit a # of different aplications and they are the ones that need a longer bolt for the hub.
JON
