Re: Farmall M carboning plugs........
Posted by John T on July 18, 2006 at 08:12:03 from (66.244.90.5):
In Reply to: Farmall M carboning plugs........ posted by dej(JED) on July 18, 2006 at 07:11:51:
Jed, Sure a weak coil can cause all sorts of ignition problems, but thats not my first suspect for now at least. If you run Autolite plugs try the NON RESISTOR 3116 or if Champion try a hotter plug also. Use wire core plug wires NOT carbon core resistor suppression wires. Dont run the carb any richer then necessary i.e. lean it for light duty use and richen it up only enough to do the job under heavy loads. If shes black smoking any excess out the stack run the carb leaner and insure the air filter n inlet piping is all clean n free. Other then that the points n condensor n wires as you mentioned and HOTTER plugs may help PLUSSSSSSSS use radiator air restrictions or shutters or thermostat etc TO GET N KEEP THE ENGINE TEMPERATURE UP can help also. Its not all that expensive to try a new coil if the spark is a faint yellow as compared to the desired visible BLUE and all else is okay. John T
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
