Re: 986 will not start
Posted by 430WLPG on July 19, 2006 at 12:25:36 from (12.25.127.79):
In Reply to: 986 will not start posted by Don Anderson on July 19, 2006 at 08:24:11:
If it is the neutral saftey switch, it has two one is under the cab on the gearshift linkage in the park position ( this one lets you start it w/o pushing the clutch)the other one is mounted through the firewall under the clutch pedal (all the wires are under the hood and behind the engine) it has most likely had the back pushed out from miss adjustment/and or dirt. If you find this the problem replace the switch DON'T HOT WIRE IT
