Re: my H went nuts
Posted by Michael Soldan on July 19, 2006 at 14:41:40 from (24.235.41.226):
In Reply to: my H went nuts posted by meathead on July 19, 2006 at 14:07:06:
Meathead, look at your fuel bowl, is there water in it, sediment?. If so clean the bowl and turn the valve on and let it run a second to make sure you have a good flow of fuel. What you describe sounds to me like a fuel problem. If the tractor was running good before and you didn't mess with the carb settings I'd bet its the fuel bowl and screen that are the problem..good luck from Mike in Exeter Ontario
