Re: Again E85
Posted by Brent in IA on July 21, 2006 at 04:59:08 from (66.43.236.195):
In Reply to: Re: Again E85 posted by Fancy Farm on July 20, 2006 at 10:38:10:
I travel quite a bit and have seen it as low as $1.00 less and as high as the same cost as regular gas. E85 vehicles tend to get slightly less MPG than gasoline (when run on E85 anyway) so the manufactureres put in larger gas tanks so the cruising range between fillups equals that of a regular gas vehicle. If you do the math, (and the fuel reatilers don't gouge on E85) the cost to fill up an E85 vehicle's larger tank and a straight gasser's tank is supposed to be equal, and the result an equal number of miles driven. The benefits are then mainly environmental and to the U.S. economy instead of some foreign oil nation.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
