Re: cold start
Posted by El Toro on July 23, 2006 at 15:10:42 from (205.188.116.133):
In Reply to: Re: cold start posted by Dean D on July 23, 2006 at 14:25:14:
I've used those heaters in the radiator hose. They did a good job I had mine connected to a timer. The tank heaters are used on the larger engines. You need that heat to preheat the engine
and to heat up the oil, then you don't kill your battery during startup. Here's a web site for tank heaters. Hal
http://www.kimhotstart.com/ Phone # 1-800-224-5550.
Phillips and Temro have block and radiator heaters. phone # 1-800-328-6108
