Final drives
Posted by Murray E on July 23, 2006 at 17:52:20 from (142.177.137.175):
One question for this evening,removed the final drives pan's this evening.The final drive on the left side appears to have a slight movement of prephaps 1/8 of an inch. The right side has no movement at all. Is this serious??. what is my next step? Thanks , Murray
