Re: Farmall A Cast Center Weight
Posted by Charles McNelly III on July 23, 2006 at 18:53:38 from (63.232.216.155):
In Reply to: Farmall A Cast Center Weight posted by flic50 on July 23, 2006 at 18:28:30:
Well, the rear add on weights on the B weigh around 132 lbs. I would imagine the hubs would be around 200 lbs. Just a guess.
Charles
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
